Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: New best in the 1/8th!!
  1. #11
    Spring, Texas
    Just make sure not to stage so fast!! I'm working on getting a line lock so I don't have to do the syty shuffle.
  2. #12
    ff_jeff Guest
    Quote Originally Posted by ramair2002 View Post
    Maybe im not all up to date on my lingo... but what in the hell is a syty shuffle? syclone typhoon dance?
  3. #13
    Spring, Texas
    Don't know what it stands for but it's when you come to the line stage both lights then press the brake all the way down. With the brake still down, put it in neutral and give it a rev. Put it back in drive and it will let you build boost without pushing through your brakes. It's because we have vacuum brakes that when you get to 0 vacuum, your brakes don't hold you at the line.
  4. #14
    ff_jeff Guest
    I should try this... with my lopey cam, I can barely brake stall at 1400rpms... it tries to roll forward. No vacuum with a lope cam... people forgot to tel me this before hand lol
  5. #15
    put hydraboost on the truck and its better.
  6. #16
    x2 thats what im goin for
    ff_jeff Guest
    splain lucey
  8. #18
    hydraboost is power assisted brakes that gets the boost from the power steering pump
  9. #19
    Spring, Texas
    couldn't you do a line lock?
