Just make sure not to stage so fast!! I'm working on getting a line lock so I don't have to do the syty shuffle.
Don't know what it stands for but it's when you come to the line stage both lights then press the brake all the way down. With the brake still down, put it in neutral and give it a rev. Put it back in drive and it will let you build boost without pushing through your brakes. It's because we have vacuum brakes that when you get to 0 vacuum, your brakes don't hold you at the line.
put hydraboost on the truck and its better.
hydraboost is power assisted brakes that gets the boost from the power steering pump
couldn't you do a line lock?
