Results 11 to 20 of 32
Thread: FLT60E Goes 9.88@140.86 in a Truck
Threaded View
    Oct 2008
    CANADA!
    HUGE THANK YOU TO FINISHLINE TRANS AND YANK CONVERTERS FOR ALL THE SUPPORT THIS YEAR
    Got a new best yesterday, Also managed a new best 60' of 1.49
    Next pass backed it up with a 9.900
    The Combo
    BOOST AT 13LBS with 75 Shot
    Truck is a 2002 S-10 originally a 2.2L 5 gear.
    Engine setup is
    370 Cube Iron block
    Compstar Rods
    Diamond Pistons
    Trend tool steel pins
    Comp Cam
    Patriot Stage II LS6's
    Yella terra Rockers
    Mamo ported Fast
    Cleavite Bearings
    ARP Studs
    Precision T76GTS
    Tial 44MM Gate
    Tial 50MM BOV
    Transmission
    Finishline Level 5 60E with Billet Output shaft --- Yes 60E
    YANK SS3600 Converter.
    Currie 9"
    3.55 gears
    MT 295/65/15 Drag radial
    Nitrous system is from Nitrodave, 90MM Plate kit with the NX Boost referenced progressive controller. Truck Is HP tuners tuned by me.
    Its a custom rear mount setup so the engine bay does not look to special.
    Here are a couple vid's Unfortunatly not the good ones.
