alright ill have to look at that when i get home.
i found a total of 4 grounds from the harness. got them all hooked up and still no start. is there another way to tell if im getting spark than pulling the plugs because i did that and didn't see any spark but i would like to find another way just to be sure
When you pulled the plugs did you touch the electrode to a clean metal part like a valve cover or something? The spark plug is normally grounded to the head through the threads, so when you pull it out you need to provide another ground for it.
2006 GTO M6 Brazen Orange
2006 Silverado CCSB Duramax
i think it touched the threaded part of the plug to the cylinder head
You can also try what I did if you have a multimeter. Make sure that it will handle the voltage first, then hook up the ground and hold the positive lead touching the contact in the plug wire. Crank and watch to see if the voltage jumps around.
what kinda voltage does it need to handle
ok nvm theres no spark what should i check
OK going back to your original post, you said that if you spray starting fluid down in there it sounds like it fires a few times. If this is true, then you do have spark. You sure that's right?
What did you put this in? Are you using a stock wiring harness for this engine?
