I might want it but we will see, not calling dibbs or anything glad you figured it out... Iv never heard of anything like that.
ya im glad i found it too ,but boy it was a PIA .now its acting like i washed my cylinders.its smoking like a whooo.and i can smell oil.1 thing after another .it had a ton of gas in the oil .i changed it twice,and this time i added some sythetic additive for resealing rings.any suggestions please add on to the list .now what ?what the hell do ya do for resealing the rings,i have synthetic in it so it limits the additives.maybe some sawdust.lol.let me know guys if you have any sugg for fixing the washed cylinder issue now.thanks ahead.
change the oil.
LOL Greg...
When you change the oil agian, pull the pan and clean it too. try to use flush before you change it. Cant hurt.
ive changed the oil 2 times and im still smoking.
how much oil is it burning? allot? is it measurable? I would think the smoking would go away eventually.
im hoping so .lol.it looks like im driving a diesel.lol
I was thinking about this earlier... And was wondering how much gas was in the oil... and for how long. Im wondering if the bearings got floated and/or valve seals are leaking...
def try a quart of lucas synthetic oil stabilizer-USE IT!!
02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
