Results 11 to 14 of 14
Thread: 1994 silverado lwb LS1 4L60E trans 3,500 - PA
Threaded View
    I hate to do it but i have to sell my truck or part it out.
    $3,500 for entire truck ****FIRM******
    or $2,300 for engine, transmission, wiring harness, and ecu (ill pull it for you)
    Truck was just inspected, good until 01/09
    Contact Me at 267-205-3589 or Email at onefastNissanZX@Gmail.com
    Truck is located in douglassville, PA
    Over 10k Invested overall!
    1994 Chevrolet Silverado 1500 LS1 5.7L from camaro
    - 148,478 miles on chassis
    - LS1 engine and 4L60E Transmission from 1998 camaro
    - Appx. 70K miles on the engine and transmission. <p>
    - All wiring connections soldered and wrapped <p>
    - Truck used to be 4wd but was converted to 2wd with swap. I still have all 4wd parts minus driveshafts and front axles.
    -Engine runs great, only driven 3K miles since swap
    - Owned by ASE certified Auto Technician
    - High flow HOLLEY electric fuel pump comes with truck but not installed, over 200 dollar pump. The truck currently has a new Delco pump installed for LS1 pressure demands.
    - Dual electric fans wired and installed, ECT temperatures stay low.
    - Has an JVC aftermarket stereo, center vents both missing
    - Aftermarket front grille installed with clear out corner lamps.
    - Euro style tail lamp assemblies installed.
    - Custom tubed driveshaft with all new U-Joints installed
    - All lights work properly - Extended cab with 8ft bed, long wheel base truck
    - Spare tire in bed
    - extang tanoue cover kit comes with truck not installed, will need new cover.
    - I didn't paint the truck but it was re-painted at one time Items that need to be completed:
    - Air intake needs to be installed, stock camaro intake tube installed now, easy to complete
    - A/C system not installed. I didnt need A/C but if you do you'll need the front accessory brackets off a 99 and newer silverado
    - Oil pressure gauge doesnt work because LS1 switch is calibrated differently. Need to install additional stock 94 switch and wire it up.
    - RPM gauge works but is inaccurate due to calibration
    - Center vents missing in radio face.
    - ECM is fine the way it is but you might want to secure it to fenderwell. I've owned it for about 2 years and performed the LS1 engine swap.
    - Small Chip in front on hood
    - Some small dings here and there
    Over 10K Invested!!! My loss your gain. THIS IS A NICE TRUCK
    Just Inspected, good until 01/2009
