Figured this would be a good place to start listing and keeping track of what I need/may need to do for the turbo install. If any of you experts think of anything, please post it up. My questions are in red...
STUFF I NEED OR NEED TO DO:
1.) Relocate PCM (due to location of air filter on turbo kit per the original owners post). Suggestions? Pictures? Below is a photo of the installed turbo encroaching into the battery and apparently the PCM area as well:
2.) Previous owner mentioned water in the intercooler. Anyone ever have that problem? Would a petcock valve (or two) be ok in the bottom corner(s) of the intercooler? $10 from Summit (or any hardware store I would assume):
3.) Looks like the kit/filter also interferes with the looped portion of the upper radiator hose. I'm just going to use some PVC elbows and try to find some straight lengths of radiator hose (do auto parts stores carry the stuff in bulk?). This is a picture of when the previous owner had it installed, you can see how it encroaches on the radiator hose:
STUFF I ALREADY HAVE OR HAVE ORDERED:
1.) Got two 25' rolls of 2" exhaust wrap off eBay:
2.) Got a new set of Taylor 409 Pro Race Wires (10.4mm) and NGK TR6 Plugs:
3.) Got a Taylor aluminum battery relocation box including disconnect switch (thanks Billy!!!):
4.) Got a Summit catch-can (thanks Billy!!!):
5.) LS6 / Z06 Cam
