Page 11 of 16 FirstFirst ... 9 10 11 12 13 ... LastLast
Results 101 to 110 of 153
Thread: 04' Colorado LS1 swap (Amy's Truck)
  1. #101
    Sep 2010
    North East Ohio
    oh thats cool, your only a hour or so from me Have to meet up at truck fest or something like that
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
  2. #102
    Attachment 7008Attachment 7009Attachment 7010Attachment 7011
    In progress pictures of the header for the drivers side, basically we are cutting several inches out of two of the primaries and rewelding them back in place to make them fit. Its better than beating the hell out of them to where they don't flow right, got the other transmission cooler line done. Until next update!!
  3. #103
    Attachment 7036Attachment 7035Attachment 7037Attachment 7038
    First pic is of the drivers side floor pan where it joins the firewall, had to ding it in for header clearance.
    Second pic is of the PNP switch, I bought a 04' Colorado PNP bare connector from the dealer for $4.90, and I used the metripak 280 series terminals to pin in the LS1 wires into the according positions.
    Third pic of the fuse box is the temporary setup with fuse taps just to get power, once we get the engine running then I will go back and permanently wire them in. I got those fuse taps off ebay, 50 for $9.99 and they work really well.
    Fourth pic is of the 3/8" hole I drilled in the firewall to run a bunch of wires inside the cab, basically wires for my aftermarket gauge pod I'm going to buy and serial data wire and cruise control wires.
  4. #104
    Attachment 7040Attachment 7041Attachment 7042
    Some of the wires I am not using were for VATS, and EVAP system. I did not remove them from the harness, I prefer to leave the harness in tact.
    Got the steering column back together today, the worst part was getting the multi function lever and circuit board back into place. That was horrible!!
    I still have to buy a flexible dipstick for the transmission, as the oem one will not work with the headers and it would have to be bent so much it would probably kink it. And I still have to buy the trasnsmission fluid, which I am sticking with the Dexron 3.
    I only have the wires inside the cab to deal with, which is maybe 8 at the most. I also have to make up two 24" extensions for the 02 sensors, so they can reach the headers. Until then.............
  5. #105
    Attachment 7075Attachment 7074Attachment 7073Attachment 7072Attachment 7071
    Here's some pics of the radiator and electric fans all mounted up in the core support, I made some brackets to hold it in place. The 98-02 F body fas work nicely behind the Colorado radiator. On a side note I got all the wiring done minus 1 or 2 wires which are for my aftermarket gauge pod I'm going to buy, we tryed to start it but the security light came on steady and nowwe have no fuel! I am goingto buy HP Tuners to get rid of the VATS on the Colorado and the Camaro.
    Can the HPTUNERS take VATS out of the body control module, because on mine that's how it's setup.
    Ignition-BCM-PCM-Fires injectors and so on...
    Well It will be awhile till the next update because I'm leaving today to go to Canfield swap meet, and hopefully I sell enough to buy the HPTuners. Until then......
  6. #106
    Attachment 7115Attachment 7116Attachment 7117Attachment 7118
    It's been a while, but here's a small update. My friend Larry cut and welded the header to make it fit, and then he put it in a press and squished the one primary to clear the steering shaft. Plenty of clearance now, both headers are on now. I am going to buy HPtuners next weekend, as that is what is holding me up right now. Until then..........
  7. #107
    Attachment 7129Attachment 7130Attachment 7131
    I bought a push button starter for my truck, as I am bypassing the BCM for this among many other reasons. I got it for $30.00, It is made to fit into the cigarette lighter but I couldn't do that as It is too low on the dash. So I decided to pull the center dash, and I put it in the blank panel next to the traction control button.
  8. #108
    Attachment 7133Attachment 7132
    I used a dremel to drill the hole out, and the button had to be trimmed down to fit into the factory bezel. All In all I am very happy with this product, It included a relay and all necessary wiring. Now I have to use the factory key to turn the ignition to "ON", and then push the button and hold it till it starts.
    So far all the lights work, windshield wipers work. Wednesday I am going to Summit Racing to buy HPtuners so until then................
  9. #109
    Oct 2011
    San Antonio TX
    Were did u get the start button from?
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
  10. #110
    http://www.ebay.com/itm/380246357496...84.m1497.l2649
    Here's the link from the seller I bought it from, he is in the United Kingdom and it only took about 10 days to get it. Normally I do not order overseas electronics, but I figured I would give it a try. The only thing I wasn't happy with was it's not lighted, I thought it was when I bought it lol!!! There are some lighted one's on ebay, and even some LED one's but they are from Hong Kong and I've gotten burned too much from that area.
    I wired the relay with the starter solenoid wires, one ground, ignition wire, and two wires to the switch. He gives good instructions too...
