Originally Posted by
slicpartna
Im running ls6 intake with associated injectors
The 5.3 dbw throttle body
Should I use the 5.3 maf or ls1 maf,
Or there no difference in the two in terms of wiring?
Is there any performance difference between the two maf sensors?
as far as ive noticed no difference but with the truck maf you will have 1 less plug due to the ls1 style that does not have the iat sensor in it. I make/modify ls1 style and truck harnesses. you will only need the oil pressure wire, coolant temp, vss and ac wires off factory harness which doesnt need the factory ecm. i just did this swap but in a 93 silverado.
Bagged 03 Sierra 5.3 swap all stock with tune and vett servo.
comp cam 228/228 588int .588exh 112lsa
g80 w/3:42's
14.41@99
