Anyone know if this same pin swap technique will work between 1997 pcm and the "411" unit with red and BLUE connectors?
As of now, I have no reverse lights, no HVAC blower.........and if the truck is running with headlights on, the ignition switch won't kill engine power. You can turn key off, then kill the truck with the headlight switch
Also, brake lights come on the second you turn the ignition switch on, and dash lights only work with headlights off.
I'm going nuts trying to marry the two PCM units together!!!!
Thanks fellers!
- You may not post replies
- You may not edit your posts
