Great info, thanks.
What do you mean about making the holes on the flywheel longer? As in widen the hole because they wont line up?
Great info, thanks.
yea. page 2. i just used a dremel and made them longer not wider. lined up perfectly. also make sure u take the tq converter off and line it up before u drop the engine in. learned that the hard way. lol
http://hotrodlane.cc/PDFFILES/Lisa%20Tahoe.pdf
Thanks for all the info, your build page is very specific. So can I just get a newer torque converter instead of deepening the holes on the flex plate? Also, what is S&P's website, I have looked and not sure if I found the right one?
