Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Torque conveter doesnt bolt up.
  1. #11
    the bolts have a GM part number.
    LS1 Flexplate Spacer 12563532
    Item #12563532
    MSRP: $53.39 Your Price: $40.04
    Qty: LS1 Flexplate Spacer Bolt 12563533
    Item #12563533
    MSRP: $6.93 Your Price: $5.19
    Or the whole kit...
    LS Series Flexplate 12621399
    Item #12621399
    12621399 LS Series Flexplate with Adapter and mounting bolts.
    MSRP: $76.40 Your Price: $57.30
    Qty:
    Note: 24238412 kit replaced by 24248985
  2. #12
    Quote Originally Posted by b18c1turboedek View Post
    Where can i get the bolts? Im going to go too Summit tommorow to get the adapter, how much longer should the bolts be? And is it the flywheel or torque converter bolts that need too be longer?
    Sorry for all the questions im new too the chevy world.
    thanks for jackin my thread...
    anyway everyone was amazing help i think i have this figured out now.
  3. #13
    Broken Bow, OK
    Quote Originally Posted by LQ9_ZR2 View Post
    I think his question was quite on topic, and the answer could only benefit other people that search this thread. You both got the answer you were looking for. WIN-WIN-WIN
  4. #14
    I just contacted Hughes about the adapter HP3795 they are saying I need the concaved fles plate also. This stuff got me so confused now. I don't even know what too do. A sawp I tought was going too take 2 days is going on 1 week now because of this converter. If I go buy the Hughes extension and the ls1 bolts wiLl this converter work on the 5.3 Flywheel?
  5. #15
    Broken Bow, OK
    I just contacted Hughes about the adapter HP3795 they are saying I need the concave flex plate also. This stuff got me so confused now. I don't even know what too do. A sawp I tought was going too take 2 days is going on 1 week now because of this converter. If I go buy the Hughes extension and the ls1 bolts wiLl this converter work on the 5.3 Flywheel?
    Hughes wants you to use the curved flex plate with their adapter, putting the adapter aft of the flex plate. The GM adapter goes forward of the flat flex plate, so you end up with the same spacing.
    You are going to need the longer bolts either way, they have to go through the adapter and flex plate on both.
  6. #16
    May 2007
    Phx ,AZ
    Wow you guys are cunfusing me just reading this. The hughes spacer plate goes on the engine side or the trans side. I know on the GM standard flex plate the spacer goes on the egine side right.
    Truck 2002 Chevy with
    old setup KB turbo kit MP70 LS1
    New setup stock for now
  7. #17
    K guys I got the Hughes adapter. When I was at summit the told me too use the stock 5.3 flexplate bolts. They said those are. The same as the ls1s. I guess I will see in the morning if it works.
  8. #18
    Thats why i suggested it many times recently.
  9. #19
    lol i forgot you hate me, anyway... thanks for the info, i ordered a hughes adapter should get the ball roling with my fitment issue now
  10. #20
    After i installed the adapter the tranny still wouldnt bolt up. I removed the transmission and found out the converter wasnt all the way back. After making sure the converter was all the way back we mounted the tranny without the spacer and it worked perfect. The converter lined up perfect without the adapter.
