Results 1 to 10 of 11
Thread: Silverado SS driveshaft
    FRONT SHAFT
    Used this shaft when I converted to awd. Not a thing wrong with it other than I went 4l80 and it no longer fits. Lucky for me my original front shaft fit. The black shaft is for sale on a diff thread, not this thread.
    $110.00 shipped to the lower 48.
    Part number 15186002
    So your z71 front shaft was long enough for the 80e and awd trans case, if so I've got one I need to put up for the future
    [Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
    Quote Originally Posted by ss wrecker View Post
    Yeah it made me happy when 1 thing went right on that swap.
    Houston
    how did the SS shaft not fit? with the reg 4x4 shaft did the trans shifter linkage work out or how are you going about that? seems to be the only problem on mine the shaft hits the linkage.
    Broken Bow, OK
    Quote Originally Posted by 408.Luke View Post
    The front SS shaft is shorter than the 4x4 one, becuase the 149 is shorter than the 4x4 cases.
    Houston
    i know this im wondering about the diameter. with the 80e and the SS shaft the linkage hits the drive shaft because its to fat
    also my ss shaft was long enough probably not the perfect length but there is still plenty long
    Both shafts were really close. The difference was the length. Nothing else. I did elongate the holes on the shifter cable bracket to make it fit and flipped the lever around so it bent more toward the trans. Works fine.
    Houston
    ok thats what we were talking about doing with mine just havent gotten there yet
    oh and BUMP!
    Bump
