Results 1 to 10 of 17
Thread: Which Walbro for OBS swap?
    Maybe racetronix appends the M in their numbering system or they just keep using it because people want to see the M on the PN. At least with Racetronix you're guaranteed to get a genuine Walbro pump and not a Chinese knock off.
    Nov 2009
    Fort Smith, Arkansas
    ... a Chinese knock off.
    Ahhh crap. I didnt know that was a problem when buyin these.
    broke1 Guest
    Yes but Jack or any other Walbro dealers offer any kind of warranty.
    Years ago when Walbro's were failing left and right,Jack was quick to tell people they had installed it wrong.
    I bought a pump from Jack that was bad out of the box and I was told "sorry,no warranty" after I got the "you installed it wrong" BS.
    Please dont take this as a stab at Jack@Racetronix.His wiring upgrades are second to none and IMO,he is the best in the business when it comes to innovative wiring solutions.He just sells crappy fuel pumps with no warranty.
    I went with the higher flowing Denso fuel pump that was original equipment on the JDM and USDM 93-97 Supra twin turbo's and havent looked back.I actually had to turn the fuel pressure down as it was up 5psi at idle vs the Walbro!!
    You guys can waste your money on a new Walbro every other year,lets hope you get lucky and it fails just cruising around,not at WOT torching pistons and head gaskets.Totally not worth blowing up for the few xtra $$$ the Denso costs vs the Walbro.
    The Denso pump is also a much better solution than the old Bosch pumps people use.The Denso has been proven to flow more than any Bosch or Walbro pump.I want to say the Denso is rated at 285lph vs Walbro 255.I have also seen flow charts of the Denso at over 300lph when the intank wiring was upgraded to 12 gauge.
    Go Denso and never worry about intank fuel problems again,EVER!
    Nov 2009
    Quote Originally Posted by broke1 View Post
    Thats the first bad thing Ive heard about Walbro pumps.
    broke1 Guest
    Quote Originally Posted by flattopwill View Post
    LOL,you must not read the net much or must have never owned more than 1 Walbro pump.
    Google search "failing Walbro" then report back
    Nov 2009
    Im takin your advice on the Racetronix kit except minus the hotwire kit. I think I can manage without it.
