Results 1 to 8 of 8
Thread: Need advice on headers and exhaust setup
    Quote Originally Posted by mr2cam View Post
    I have one more question too, I bought a set of precision 42lb injectors off of a guy from ls1tech.com, but they are a lot taller then the stock 6.0 truck injectors, the only way I can see making them fit would be to put spacers on where the rail bolts into the intake manifold, is that normal? I will take a picture of the injectors when I get back from lunch.
    Very common. They must be fbody LS1 injectors.
    So there shouldn't be a problem if I put a spacer on the intake manifold where the rail bolts on to?
    not at all, a very common modification. Usually those injectors won't be plug and play, you'll need new pigtails or adapters to wire the injectors into the harness.
    Ya they are definately a different style, I found some adapters from FAST that I think will work. Anyway thanks for your help.
