Originally Posted by
keniff
thanks redheartbeat! i sent my heads to be milled .030 to bump the compression...6 weeks later still not touched. got them back an left them alone. it actually made me mad bc i was counting on my heads being milled and running a higher compression. but oh well, it just taught me not to ever go back to them an everyone i know i will recommend them to stay away from them.
dumb question, but...
where to get the red scotchbrite pads? only thing i remember seeing are green ones.
redheartbeat: i looked through your garage pics an didnt see any pics of the radiator..did you trim down the bolt tabs considering the stick up past the radiator support or did you cut the bottom out an make it lower that way you could use the tabs to bolt it in. any ideas would be great before i cut up my radiator
