A friend of mine blew his transmission in his 02 5.3 ECSB. He found one on craigslist for but it's out of a 06 5.3. My question is will it be a direct swap will everything plug up the same? Thanks
01 GMC Sierra 4.8
6" Fabtech lift & Shocks | 3" Body lift | K & N Air intake | Flowmaster duals | 22" KMC Rockstar wheels with 325 50 22 Nitto All Terrains | Billet Grille |
Yes, direct swap if they're both 2wd or both 4wd transmissions.
yeah they're both 2wd and out of a 5.3. Thanks for the help
01 GMC Sierra 4.8
The only thing you need to swap over is the Prindle switch. The 99-03 trucks had the 2 plug setup, and the 04-07 Classic trucks had the single plug setup.
[Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
OP edited. I knew it was either the 03 or 04 model year when they changed Prindle switches.
Yeah, when taking the Prindle connectors out (on the 2 plug setup), make sure to get a lighter and heat them up for like 10 seconds before trying to get them unconnected. If you don't heat them--you WILL destroy the connectors, and possibly the entire Prindle switch.
Thanks guys I'm buying a 5.3 and tranny to swap out my 4.8 but i'm sellng the tranny to a friend since mines 4wd. Just wanted to make sure it'd work before I bought it.
01 GMC Sierra 4.8
