Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 57
Thread: thinking about building a sleeper
  1. #11
    Spring, Texas
    Quote Originally Posted by 02sleepinbeauty View Post
    well i was pretty much wanting it to appear to be almost stock. and i was going to put an h-pipe on it as well prolly with the cats gutted.
    Are you wanting it to appear almost stock driving down the road or with the hood open or both?? I haven't changed anything appearance related on mine and even had the stock tailpipe put back on. The only thing you can hear is the rumble of the exhaust when it idles like it has flows or something. People don't find out the rest until it's too late!!
    I am about to change a little bit just to try and instigate a few more runs....
    (Hint: License Plate)
  2. #12
    Quote Originally Posted by sleeper1500 View Post
    Of course I'd have to chime in on this, a turbo or supercharger are dead giveaways because of noise, as are massive cams so there's only one real internal power adder left. Compression. Mill those 243's or get 706's of a 5.3 get it up around 11:1, a cam with a fairly wide LSA (Like 114) a nice quiet exhaust with a cutout added and just to make sure you don't bring a knife to a gunfight a nice shot of the good stuff.
    Wow, Devin actually made a worthwhile post!
    Quote Originally Posted by keniff View Post
    6.0
    243s milled p&p
    TBSS intake
    LS2 90mm TB p&p
    Custom 4" CAI
    150 shot
    220/228 .581.588 113+4 cam
    LT headers
    3" exhaust cut out
    4:10s
    3200 stall
    sleeper material IMO
    VERY nice list. Take that list, run stock height suspension, stock wheels, stock muffler and tail pipe, and stock engine cover. Then go munch on some Corvettes.
  3. #13
    well yea, i was wanting to appear stock. like with the stock suspension and everything. as well with under the hood. as a matter of fact iv been just thinking of 6.0 with the 243 heads, h-pipe with some delta flows and a locker in the rearend. i had some deltaflows on my 5.3 and everyone thought it was a 4.3. and of course a tune.
    02 rcsb 5.3, h-pipe/flows, 3.42 posi, tune by trt. best 9.5 1/8 @ 76mph before tune and poor traction
    Now im at a 9.2 and still bad take off.
  4. #14
    Oct 2009
    O'rly?
    People mistook a V8 for a V6?
    They sound completely different.
    8 guns firing into a barrell sound nothing like 6.
  5. #15
    socal
    if you plan on putting a 6L in it look for a v6 truck to buy. they're much cheaper
  6. #16
    Quote Originally Posted by GRsilverado View Post
    And more difficult.
  7. #17
    i would get the 4.8 just to have the extra power while driving it till you got the 6.0 built
    edit: and im with tyler on the build up of the motor. that would be sweet if you could stand to leave the truck alone. most can't so not lowering it or whatever might be a challenge. i know it would be for me.
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
  8. #18
    wichita falls, tx
    And more difficult.
    depends on the year...99-02 are simple!
    after that get more difficult...
    Intro Radicalli's
  9. #19
    It happens from time to time.
    Quote Originally Posted by banker099 View Post
    And yeah if you do a swap do a 99-02, 03+ is a whole new deal.
    Augusta, Ks
    Y are you dead set on the h pipe? Just get long tubes and an off road y pipe and then get a quiet muffler. I have those and a 50 series 3 chamber flowmaster. Its real quite until you open it up.
    2004 Buell XB12s
