Quote Originally Posted by Toadz View Post
I doubt that it'd be enough to hinder any more performance than the actual bend will. Remember the intake can only flow as much as the throttle body will let through. The ideal intake is should be as straight as possible.
Okay, if thats the way you feel, go get a 4" pipe bent at an exhaust shop.. At the bend, it may cut it down to as small as 3". Just go get a 3" pipe and put it on there. It'll flow the same as the 4" with the 3" bend.
I guess you want to tell me porting and polishing heads and throttle bodies does nothing too. Why does an ORY flow better than a stock Y? It's mandrel bent. No restriction.
