Results 1 to 5 of 5
Thread: remote start question
    Oct 2008
    Killeen, TX
    I found mine tucked nicely underneath the steering column in a metal sleeve. Only way to see it was to take off the piece that your knees would hit if you are sitting in the drivers seat.
    2007 Chevy Silverado Classic 4.3L V6
    Magnaflow Muffler, CFM Technologies CNC Machined High Flow Vortec Throttle Blades, STS Rear Turbo, Intercooler, Accell Distributor and Coil, 8mm wire, Autolite Platinum plugs, Runs out of fuel at 4000RPM. Marine intake with larger injectors soon. Hoping to squeeze 10psi.
    Wichita Falls, TX
    Quote Originally Posted by Wildman View Post
    he's got a nnbs, not the same. but the bcm is behind the knee bolster still, so you were still right.
