Results 1 to 10 of 43
Thread: FAIL of the day
    Houston
    FAIL of the day
    do i need to say anything else....
    Jul 2009
    I see that ending badly! What is going on there?
    01 RCSB Race truck that is slow.....
    Houston
    i drilled the bottom hole first (for my turbo oil return) well i did the corect 3 drill bit step up thing went 3/16 to a 3/8 to a 9/16 (the size hole u need for the 3/8 npt tap) so first bits go through like butter nice neat holes then after buying 2 yes 2 9/16 bits today i get one that fits my drill press stick it go to drill the hole and it cut it rough and wabbled out some and wouldent tap, the hole with the fitting i drilled one hole with the crapy 9/16 bit and it did fine through the tap through it and put the fitting in now i have to dig up another front cover...
    ff_jeff Guest
    so you tapped the hole with a press?
    Houston
    no i drilled the hole with the press, taped by hand
    Apr 2005
    Y not just weld them on?
    Gone, but not forgotten!
    ff_jeff Guest
    Quote Originally Posted by SCIV View Post
    Thats what I was thinkin. Think with your dipstick jimmy!!!
    Houston
    cus ive never welded aluminum and its quicker than goin to jon's i wish i would have thought about it when i did the valve covers
    Houston
    oh and not welding it makes it that more fail!
    Apr 2005
    Box it up and send to Jon.
