Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: track times disapointed........
  1. #11
    Agree.
    The minimal gain in short times is probably better leverage of the gears vs. worse traction but laying over up top is a problem as is the vibration.
    Where are you shifting it?
  2. #12
    Slimsilverado Guest
    Ditch the double dueces......
  3. #13
    Richardson
    Have u got a tune, man w/ that cam, stall & gear u should putting down some good times. I'm running a LS1 218/500 cam w/ stock trans and convertor w/ 373's. and Running mid 14's on motor..
    2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
  4. #14
    Feb 2009
    Seminole TX
    the cam and stall were installed by texas speed and performance the gears i installed myself but it was all tuned by texas speed i dont know really when it shifts but i know when it hit 3rd it starts to vibrate i think its rite at 80mph. do yall think the times and the vibration have to do wit the gears?
    2005 5.3 comp cam 220/220/581/581.lsa12...volant cai....3000 vigilante stall... 4.10s..Detroit truetrack lpp long tubes with ory to a flowmaster turndown 22"BOSS with 285/35s Nitto NT555s
  5. #15
    if you're in third gear at 80, what rpm are you at? That is the RPM you need to have the driveshaft balanced at. If your local shop can't do it, find one that can. Also, see how much slip yoke engagement you have. Your slip yoke should not have more than 1" of slide before it bottoms out, otherwise it can wobble on the splines and cause an imbalance. Also be sure your tires are balanced at the speed in question, if possible. Most shops don't have adjustable speed balancers for tires.
  6. #16
    Mine shifts to 3rd at 5900 near 80 and I have about the same height tire combo so it's close to what it should be.
  7. #17
    Feb 2008
    Arizona
    I ran 15.88 with just shorties, cai, catback and fast flash programmer.. I have the same cam, stall & gears as you do now, will be getting times soon and will let you know how I do..
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
  8. #18
    sorry bout the bad luck man, real quick how long did you drive on those new gears before hittin the track and how long before you went and hammered on it?, suprised this hasnt been asked yet.
  9. #19
    Feb 2009
    Seminole TX
    I put about 100 miles before I hit the track and gave it about 5 heat cycles before I got on it
    but still took it easy
  10. #20
    ok, thats what i was wondering.
