Results 1 to 9 of 9
Thread: Questions about my 6.0 swap
    Aug 2009
    Pompano Beach, Fl
    I just did a swap to a 6.0 in my 99 5.3 silverado. everything went smooth. Only question i have is the 6.0 dosnt have an EGR valve. what year did the 6.0 not come with an EGR? I am throwing a Check engine light now because the comp isnt finding the EGR since it isnt there. How do i fix this?
    you need to turn it off in your tune when you update the tune for the larger engine. You may be able to put a resistor inline to fool the PCM into thinking the EGR is there but I've never seen anyone do it.
    Aug 2009
    Pompano Beach, Fl
    i was told that i wouldnt need to re-tune the comp for the 6.0.
    Hutto TX
    Quote Originally Posted by grneyedloki View Post
    You don't...
    ...if you think that your PCM is one of those with dynamic-cubic inch upgrading capabilities! Heck, you would notice a night and day difference on your 5.3 had you got your PCM tuned by a reputable tuner. It would be the second best upgrade you ever did to your truck, second only to the actual 6.0 swap
    1991 Silverado ECLB
    LM7-T56
    your fuel trims are going to be terrible without an update. Everytime the PCM gets disconnected it will have to relearn, it will start out running very lean and then learn to add fuel. Get the tune updated for safety.
    Aug 2009
    Pompano Beach, Fl
    which tune do you recommend? BB?
    Hutto TX
    NelsonPerformance...dot coooooooom!
    I have one of his tunes. Swapped a 5.3 and T56 into 91 Silverado AND did the 95 dash at same time, and it fired up first time and runs great. Passed emissions with flying colors, a blast to drive, no codes. What else can I say?
    1991 Silverado ECLB
    LM7-T56
    where are you located? A live tune by a professional tuner is your #1 option. If you're in a location where you cannot get the live tune then the NP mail order tuner is a great 2nd option. They can do a live tune for you if you don't mind driving down to SanAntonio.
    Aug 2009
    Pompano Beach, Fl
    a little far from there. I am located in miami, florida
