I got an eaton, and no problems.
03' Silverado RCSB H/C 5.3, 4L80,76mm KBracing Kit
13' Sierra Denali 2500HD CCSB 4x4
The only place I recommend you going to Zach.
Basically, and Eaton or Auburn uses clutches and bands to make the posi happen, kinda like how a transmission uses clutches and bands to shift gears. The only thing about that is we all know how well bands or clutches can wear out or not grab. The TrueTrac uses straight-cut gears to make the posi happen. No slipping of any sort, like bands can. I am sure the Eaton is a great unit, but I would go with the Truetrac only because of how it is built, the price, and how reliable it is.
