Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 35
Thread: Stuck in 4lo!
  1. #21
    That has nothing to do with being stuck in 4LO. 4WD maybe, low....no.
    If you unplug the actuator in the front diff the transfer case will not change into anything other than what it is in.
  2. #22
    Depends on which range you start in.
  3. #23
    I did not try it in 4 lo. Just 4hi and auto4wd.
  4. #24
    Aug 2004
    Houston, Tx
    Well if the actuator isn't letting it go from 4wd to 2wd the I guess the same would happen from 4lo to 2hi since it still needs to disengage the front axle?
    '04 Z71 5.3 Coldair kit, leveled, ranch hand bumpers
  5. #25
    Aug 2004
    Houston, Tx
    Replaced the actuator a little bit ago, and still not working. So far I'm down $93 with nothing to show for it.
    So that leaves the encoder or dash switch. I get some various signal voltages from each range, but don't even know what they should be.
  6. #26
    You need a scan to pull codes for the transfer case module and to check data. This would cost less than $93 even at a dealer. If you were closer I'd help.
  7. #27
    Aug 2004
    Houston, Tx
    Scanned it and got a C0379 front axle circuit malfunction code. So I guess it's not the encoder?
    Encoder v: 3.43
  8. #28
    Not a common code which to me leads to wiring damage in most cases.
  9. #29
    I got .50 cents on GG being right.
  10. #30
    Where did you get half a penny Jake? Dang ole moonshiners....
