OK, so I'm thinking about putting my tru cool 40,000 cooler i just got ($110 shipped with bypass valve) AFTER my radiator. My stock set up keeps my trans temps pretty cool highest i have seen stop and go driving around is about 195 in 95* Texas heat. Not too bad. I have read of a few people running very low tranny temps with this cooler so i was thinking of putting it afterf my radiator, right before the fans, so my radiator can get the cooler air and keep my engine temps lower. Will also make my A/C blow a little colder.
I'm also thinking about bypassing the stock tranny and oil coolers in the radiator so only coolant is going thru there. Wanted to use my stock external tranny cooler for my oil and run that after the radiator as well.
Ideally I'd like everything to run at about 180*.
What do you guys think?
