I think I have a date.
Holy smokes,thats alot for a meth kit.
I looking forward too, to see the results![]()
ugh...finally got it working...I screwed up one of the grounds so the pump wasn't coming on. And the float in the tank came pre-installed upside down lol. So anyway, all fixed. The methanol sprays off the voltage of the MAP sensor which reads from 0-5v. for some reason Virgil and I could only get it to come on if we set the programmer to come on at .1v and off at .2v - so I have to figure that out. But it was spraying good (water only for now, outside the vehicle), now just gotta get methanol and get the tune looked at and then dyno it on Saturday!
