Originally Posted by
Circle-D
We have built a lot of 6L80 converters. We have them in the 245MM or 258MM version. Single disk or multi disk. I send a lot of them over to Australia for the Holden. Those guys really like to race and I love the accent. But back to tour question. When we were first testing them, the tuners were having some issues, bumping the rev limiter and not shifting. Most of that is worked out now and we have some of the fastest G8 and Holdens out there. Not real sure if that answers your question, but I have not had any burn up. Just some shifting problems because of the higher stall.
As far as the stock verter in the 6.2 with the 6L80, it will be the 300MM low stall. So same converter they were using in the 4L60, just setup for the 6L80. Probably rated at 1500-1700.
Chris
That is what I wanted to hear Chris. I guess Yank and the others need to buy your converters and learn your secrets. LOL. Can you loosen up one about 500 or so rpm's for the wife's Denali? Not looking for anything crazy just alittle bit more take off and better MPG's.
Are you making the Billet covers for the 6l80 converters?
thanks,
2009 YUKON DENALI,BLACK ON BLACK, LS3, Dynomax 4" cat-back, VARA-RAM INTAKE, KOOKS LT's, MSD IGNITION, LS VVT hot cam, ZO6 springs, HP tuned to 421awhp, 12.54 at 108mph on 24's.TUNING FROM THE DARKSIDE.
06 KAWI BRUTE FORCE 916cc 6.80's in the 1/8th. ALL MOTOR. New found drug addiction is getting "HER" into the 5's. "EVER HAD A QUAD TAKE YOUR MONEY?"
