Results 1 to 10 of 40
Thread: New engine, popping under boost??
    So, if they are the heads, bent valve, bad seat, etc, what do you think?
    One of those. Now put them back on and let's do a leak down to find out.
    If you have a short block lying around and a beernight you could try them on that. You can also turn the head over with the chambers sitting up and the deck level and pour some solvent in the chambers and look for the valve that drains into the head. This will show a leaking seat. Take that valve out and then check it for straightness. If it's straight, the seat or valve job is the problem.
    ... This will show a leaking seat. Take that valve out and then check it for straightness. If it's straight, the seat or valve job is the problem.
    Ok, I just tore the engine down and I'm going to reinstall the heads to do a leak down, LOL yeah right!
    I can turn them upside down and fill the chamber, that's about all the time I have.
    I'll just sent them off to the machine shop, have them shaved, reworked, valve job and new valves put in them.
    Oh well.
    Oh well.
    JR the guy who does the head work up here is freakin awesome. PM jon or kurt an they will get you his info.
    That was a joke
    Did you try the solvent test?
