Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 79
Thread: My new motor BLEW!
    Dec 2003
    Azle,TX
    My new motor BLEW!
    pistons everywhere! pics to follow! and no its not april fools! Ask Tyler. I am so EFFED!!!!!!
    Vortec Performance Tuned
    oh (multiple expletives deleted)
    You have got to have a severe detonation issue to kill two engines in the exact same manner. Its like your PCM isn't recognizing knock. Is your fuel pump dying? When you get the engine back in you can borrow my dual sensor wideband and drive with it for a while until you're for sure you have no fueling issues.
    Jul 2006
    College Station, TX
    Tisk. Tisk. Tisk. Are you blond?
    2004 EXC Silverado 6.2L
    Mods:
    Slimsilverado Guest
    nope he is gray bush!!!!
    Jun 2007
    Seriously!Im sorry to hear this.
    wichita falls, tx
    oh no....that sucks dale...sorry to hear it ....i had a 5.3 long block in my shop, and i just sold it monday....oh and
    Intro Radicalli's
    Oh snap, sorry to hear Dale thats alot of work to go thru just to have to do it all over again
    2008 White Sierra Denali 6.2L/2WD
    Apr 2006
    Bellevue, Nebraska
    WOWWWW, that effing sucks. Hope you find out what happened to it.
    Dec 2003
    Azle,TX
    26 degrees timing with 93 plus lucas octane booster...it wasnt pinging!The piston skirt is burnt...possibly damage before i got it.Ill know more when i get it down.
