pistons everywhere! pics to follow! and no its not april fools! Ask Tyler. I am so EFFED!!!!!!
Vortec Performance Tuned
oh (multiple expletives deleted)
You have got to have a severe detonation issue to kill two engines in the exact same manner. Its like your PCM isn't recognizing knock. Is your fuel pump dying? When you get the engine back in you can borrow my dual sensor wideband and drive with it for a while until you're for sure you have no fueling issues.
Tisk. Tisk. Tisk. Are you blond?
2004 EXC Silverado 6.2L
Mods:
nope he is gray bush!!!!
Seriously!Im sorry to hear this.
oh no....that sucks dale...sorry to hear it....i had a 5.3 long block in my shop, and i just sold it monday....oh and
Oh snap, sorry to hear Dale thats alot of work to go thru just to have to do it all over again
2008 White Sierra Denali 6.2L/2WD
26 degrees timing with 93 plus lucas octane booster...it wasnt pinging!The piston skirt is burnt...possibly damage before i got it.Ill know more when i get it down.
