well my transmission took **** on me on the way to work yesterday 103k miles. It started earlier in the week having problems shifting from 1st to 2nd. It either would not shift until about 4000rpm or you had to let of the gas and get back on it easy for it to shift. The rest of the gears seem to shift fine though except if you floored it and then it would tach out again. Now it still does the 1st to 2nd thing, but it will not shift out of 2nd gear. I even shifted into 3rd and it does nothing but rev up. Any ideas? Shift solenoids, converter, clutches? There is no engine light on and my code scanner only reads DTC''s not trans codes.
_____________________________
2002 Silverado Z71 5.3L Ext.Cab
Deleted Cats.
Predator Tuner
K&N
M/T LT285/75R16 Baja MTX
