Thought I'd stop by the site after meeting some of the guys.
 WTH JUST HAPPENED?
						WTH JUST HAPPENED?
						WelcomeWere you out at NorthStar Dragway Saturday night?
Welcome!
Hey welcome to the site.
Thanks, you were one of the guys I met if the avatar is correct.
(speaking of the post above)
Last edited by GasGuzzler; 08-03-2008 at 09:34 PM. Reason: Original version not clear, forgot to use quote function
 mitchcobbracing.com
						mitchcobbracing.com
						welcome!
good to see you over here, im also on denali trucks
01 Silverado
Welcome to the site!
 Member
						Member
						Welcome!!
Daily beater: 1997 Ford Escort
WIP: 96 S10 - 408 stroker: LQ9/T56 Swap, Callies Compstar Rods/Crank, JE LSx FSR Pistons, L92 heads w/.660 spring upgrade, Synergy custom Cam, 90mm Nick Williams TB, Yella Terra 1.7 rockers, Sanderson's LSx conversion headers, Compcams Magnum pushrods, Strange Prostreet 3.73 gears, Corvette C-5 brake conversion front, Firebird Trans-am conversion back, 03 Cobra injectors, Nelson tuned CPU/Wideband,
