honestly you should have no problem taking him..
A stock 99 Lightning puts out 360 hp...but more importantly--440 ftlb of torque. That is their Achilles Heel--they have such massive low end torque-which makes them hard to launch. They are probably putting a little over 300 hp to the ground.
Your truck is pretty close in the hp department. But you have the luxury of a closer ratio 6-speed transmission. The Lightning only has 4 gears.
There is only really one more thing to do to create more power--a bigger cam. If your truck is not putting out the power you want, you could probably bump up the cam size to a 224/224 .588/.588 112. It would work pretty good with your 6-speed manual tranny.
P.S. You tried to fit some F-body LT headers on there?
wow they put down that much huh? thats pretty crazy... a couple of my buddies drove the truck and said it went good. id really rather not change my cam. i need an intake still which ill probably order tomorrow i have been borrowing my buddies stock 5.3 intake from his truck. i suppose i can always go the nitrous route. i suppose i should probably see what the truck will even do in the 1/4 etc etc ive never owned another "fast" vehicle and havent run anything i would condiser insanely fast i suppose the lightning will give me an idea where i stand. and no i havent tried FBODY LT's i was told nothing fits and so i custome made my exhuast from the manifold all the way to the muffler its 2.5 inch stainless and it Y's about 6 inches before the muffler. i will buy a set of lance when he finishes them. as far as nitrous goes though id probably only run a dry 100 shot. but i know nothing about nitrous and timing and installing it etc..
