Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 43 of 43
Thread: Truck threw 9 codes on the way to work. HELP!
  1. #41
    From the dealer its probably $20+. Allen can probably sell him a whole connector body and retainer for a lot less than that. Then all he has to do is push the wires out of the connector body and push them into the new one. The trick is releasing the tab that holds the connector in place. I use a staple and slide it down the connectors slot to release the lock tab and slide the connector out of the plastic body. Putting it back together is as simple as sliding the connector into the new connector body. That would be the right way to fix it if Daniel's that detail oriented.
  2. #42
    ...all he has to do is push the wires out of the connector body and push them into the new one. The trick is releasing the tab that holds the connector in place. I use a staple and slide it down the connectors slot to release the lock tab and slide the connector out of the plastic body. Putting it back together is as simple as sliding the connector into the new connector body...
    +1
  3. #43
    Mar 2008
    Wichita Falls, Texas
    LOl..Tyler why are you always linked to problems?...lol J/k
    http://www.ls1truck.com/forums/image.php?type=sigpic&userid=4251&dateline=1206558  920
