I've been eying the Isky cams. What are the specs? Also, are you running in 4wd? Traction issues? What tires?
A great problem to have: "sir, you need to leave if you don't have a cage".
Im running an old ISKY SB chevy profile. 212/212, .527", 114*. The lobe started out as a 209* @.050'', but grew to 212 on the larger LS1 core.The new lobes they just came out with are alot better.
I run in 4wd with 28'' tall ET streets on all 4 corners, traction was an issue I think mostly because both times I have ran the ET streets, it was opening day, on a new track surface.
-03 GMC, Rc, 4x4, 6.0L, JFR Isky, JFR 317's KBRacing T78/68
Boost only, Daily driver.
