You will be in the low 10's for sure, and most likely in the 9's with ~18psi. The difference between 10, and 15PSI is huge on a T76. I can't imagen what 15PSI down there at sealevel would feel like. What's that thing weigh?
-03 GMC, Rc, 4x4, 6.0L, JFR Isky, JFR 317's KBRacing T78/68
Boost only, Daily driver.
Truck weights about 4280lbs with out driver, I already have some race seats and a lift off hood so it might weight less even after the cage its done.
I just know that when I had it at 7psi and then I would put 12psi it would make a huge difference, we'll see what it does with 15psi and if Allen wants to try 18psi he is welcome to do so.![]()
2001 GMC Silverado
Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
