Results 1 to 10 of 23
Thread: New Best 10's finally
    Feb 2005
    I just got my 10 second pass 10.96 @ 124.32 with 10psi and truck spin just a bit with 6psi off the line, my 60' was worst then the first pass. Here are the details of my 2 passes.
    1st Pass
    60' 1.58
    1/8 7.04 @ 97.83
    1/4 11.06 @ 122.39
    2nd Pass
    60' 1.63
    1/8 7.00 @ 99.48
    1/4 10.96 @ 124.32
    The guys at the track did let me run after my 11.06 pass with out the cage but this was the last time they said.
    Here are the timeslips
    2001 GMC Silverado
    Stock Bottom End LQ9, MS3, Stock 317's, Victor Jr, Aron's Elbow, 90mm TB, 1 7/8 TSP headers, FLT 4L80-E, Rossler Trans-Brake, 3600 PI TQ, 4.10's, 31" tire. Nitrous Dave System with Zex plate. On 150 shot 10.53 @ 128MPH 1.51 60'
    Old Setup = Trick Turbo Kit Tuned/Installed By Nelson Performance 10.78 @ 127.08 1.62 60'
    Aug 2004
    Magnolia, TX
    congrats JJ!
    San Marcos Texas
    Great job JJ!
    Jan 2006
    That is great! Finally. Turn up the boost for low 10's after the cage.
    I am anxious to see what mine runs when I get the scorpion rockers on and move the cat converter back behind the cutout.
    Very good runs JJ!
    Jamest
    12 Sec. Club! SOLD
    SOLD***
    Oct 2006
    Wichita Falls Tx.
    Great job JJ nice to see. So no more running until you get a cage, Good luck in the future for quicker et's.
    Online Store
    [/CENTER]
    Apr 2005
    That is hauling balls JJ. Congrats!!
    Gone, but not forgotten!
    ff_jeff Guest
    Awsome man, Glad its workin out for ya.
    Feb 2005
    Thanks guys, as soon as I get the cage I'll be going to SAR with Allen to try 15psi, what do you all think it can run?
    2001 GMC Silverado
    ff_jeff Guest
    Quote Originally Posted by JJ_TURBO View Post
    I am going to guess 10.25 @ 130mph
    its going to be running too fast.. lol
