Results 1 to 10 of 13
Thread: 160 degrees tuned.. but not on it..
    ff_jeff Guest
    the thermostat does pop out of the housing. And if you get a thermostat, you can get a LS1 thermostat. eBay Motors: Mr. Gasket 6367 Hi-Flow LS1 Thermostat 160 deg. (item 200202247463 end time Mar-23-08 07:40:58 PDT) I have this one, but I bought it from autozone.
    yeah, all you need to modify the stat is a BB stuck in the stat center pin. Theres a how-to topic here somewhere on how to do it.
    May 2007
    Elmira
    Quote Originally Posted by vff_jeff View Post
    Does it fit in the same housing or did you have to modify that? I can buy one in the housing for like 35 bucks, but i'd rather spend 12 if possible. Thanks.
    ff_jeff Guest
    it pops right in... hardest part is getting to the bottom bolt of the two on the waterneck. But yeah, just pull out the old one and push in the new one.
