Results 1 to 10 of 10
Thread: 408 90mm TB & intake swap questions
Threaded View
  1. #3
    Apr 2005
    Call Ketech's tech support line on the electronic adapter issue. The spacers you already have will probably work, just need the correct orings. They're available from sdparts, Katech or Ebay. The spacers are about 5/8" tall, probably the same as going from truck to fbody injecters.
    They are already closed...damn east coast.
    So, if it was 5/8" to go from truck to fbody 60lb injectors, then it would be another 5/8" to make up the difference on the LS2 intake? So 1 1/4" total?
    Will I need a tune to make it operate? I know I will need a retune for optimum performance, but will it run after the swap?
    Gone, but not forgotten!
