i forgot to mention i'll be running a set of 26x10.50 et streets so that may help alittle bit??? without a stall would 4:10 gears helpout any?
Originally Posted by
farmtruc
Keep in mind ET has to do with how well the truck gets off the line, MPH is how fast you go down the track. Get off the line and you'll run a 13, but don't get off the line and you'll run slower, but still have a good mph.
You truck will be violent and strong from a roll though.
see you online,
allen
1999 5.3 ex cab 3/5 drop, k&n CAI, BBK 80mm TB, Pace setter longtubes, 3" ory, hooker aero muffler, TS 224r cam w/112 lsa, comp cam 918 springs, TS chromoly pushrods, 180 degree thermostat, Nelson tune, 3 angle valve job, electric fans, 28x11.50 et streets
