what type of welder are you using to do that? also do you just keep tacking the roll pan until it makes a complete weld all the way down ?
My roll pan always cracks out. The last time it was done, the crack started after only 2 months. I've also got a crack by one of my Caddy tails.
hopefully thats what mine looks like when i get done it looks good mayne
im thinking i probably wouldnt be able to do it to mine as my body line is different and i would be left with a tape line at the very back near the tail light ill have to look at it. my body line tapers in and levels with the bed at the very back. been there done that haha... sucks
No No.. I can burn something in, right in the middle of a bedside and you cant tell. This is what you do, you get foam masking tape(we call it rope), use that on the edge of the tape so that it causes it not to leave a tape line, then on the first coat of clear stay at least 3 inches from that rope, leaving a dry spot. On your second coat of clear, clear up to the rope, then immediately after get some Hot temperature reducer and dust that over the paint line where the rope was. That melts the new clear into the old clear, leaves a little line, but the line sands out very easliy with 1500 gritt paper. Then buff it and BAM no one can even see it, not even me. Did you stay with me there? Or do I need to get pics?
