Thread: nos ?
    May 2004
    A 50-75 shot will work fine. Just use the TR6 plugs like Jeff said and retard the timing 2 degrees when you spray. Rule of thumb is 2 degrees for every 50 shot. The window switch will help save the tranny and give you a little more comfort. I was pushing a 150 shot without a window switch but I could afford a new tranny if I screwed it up. It's you choice. LOL the higher octane will help out also but you'll be fine on 93 octane. You're putting one of the safest shot amounts on your truck. A good friend of mine is spraying a 100 shot with just TR6 plugs and it's a 2000. We installed our nitrous at the same time which was back in 2000 and his truck still runs fine. We must have gone through 20 plus 15lb bottles of juice on the street and never once got pulled over. LOL
    Good Luck!
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Jun 2007
    Quote Originally Posted by NITROUS View Post
    Good Luck!
    i already have tr6s for the f/i ,but theeyre at 35 .should i change the gap ?and everyone says back off timing 2 degrees for every 50 shot.how do you know that some people are running 20 degrees initial timing and some some are running 28 dgrees so whats the deal with that? .i think im running 21-23 degrees.?
    May 2004
    21-23 degrees should be ok but if you really want protection you can get a timing tuner from Nitrous Outlet or possibly Allen Nelson. I haven't messed with too much of the timing tables in HPTuners. Leave the gap, .035" will be fine. I wouldn;t go over .040"
    97 GMC, 2002 LS6.
