Originally Posted by
02CHEV
I got my new fuel pump in last night at midnight. took alot longer then I was planing being the second one I have done this year. I bought my pump from Billy at TRT Turbo. Man does that thing make a night and day diff she really goes now. I also found out that I have a bad IAC sensor and the rear brakes r shot oh well but at least I can squeel and peel
i saw you were having a hard time ,did you use the zip tie trick i told ya too ,to hold it in ?
