Results 1 to 8 of 8
Thread: Got my new pump in
    Sep 2006
    Coon Rapids, MN
    Got my new pump in
    I got my new fuel pump in last night at midnight. took alot longer then I was planing being the second one I have done this year. I bought my pump from Billy at TRT Turbo. Man does that thing make a night and day diff she really goes now. I also found out that I have a bad IAC sensor and the rear brakes r shot oh well but at least I can squeel and peel
    04 Grand Prix GTP
    03 Z71 wanting a Turbo ,Stall, and Tune BAD
    THE SURGEON GENERAL SAYS NOTHING ABOUT SMOKIN A FORD
    Dec 2003
    Newark, Tx.
    glad you got it taken care of.
    Jun 2007
    Quote Originally Posted by 02CHEV View Post
    i saw you were having a hard time ,did you use the zip tie trick i told ya too ,to hold it in ?
    Jul 2007
    eastern shore of virginia
    how did the fuel pump make such a difference? were you maxing out the stocker?
    2008 Trailblazer SS LS2, K&N CAI, flowmaster 40 series, hp tuned
    2004 Trailblazer 4.2, K&N CAI, hp tuned
    2002 Camaro Z28 5.7 ls1, lid, slp loudmouth, bbk longtube headers, ory, hp tuned, tr224 cam, ported 243 heads, moser 12 bolt w/ 3.73's and full spool, and a 100 shot just in case. 463whp, 458 wtq 11.32@ 120 1.52 60' on motor no spray times yet
    Sep 2006
    Coon Rapids, MN
    Yes to the zip tie
    the stocker was bad only. 40 psi when truck was running
    04 Grand Prix GTP
    Apr 2005
    Yes to the zip tie
    How are you monitoring FP?
    Gone, but not forgotten!
    Sep 2006
    Coon Rapids, MN
    had my father inlaws fuel press tester but I am going to buy a fuel press gauge so I can monitor it.
    04 Grand Prix GTP
    Slimsilverado Guest
    I did the same thing took me a while after busting 2 fuel pump lines i setteled on blue 300 psi fuel hose and stainless clamps that are smooth on the inside and notched the plastic houseing to accomodate the head of the screw in the clamp. I have not had any problems since then.. I am an expert now im removing the fuel tank from my truck, I can do it alone in about 10 minutes...Mine idels at 50 psi and under load runs close to 60 psi. One question for you guys some time under heavy acceleration i hear what could be knocking or pimping or something. Seems to make a sucking noise above 4000 rpm and thoughts????
