Well I just got them on, wish i could leave them open, but oh well.
Hey big thanks sent out to Mean05 (Virgil), Great seller.
My Ride: 2006 Chevy Vortec Max, LQ9, 4X4, no cats, 50 Series Flowmaster in factory pipe, 20"s, C.A.I., Custom tune by Dustin at TRT Performance
Well I am having a small problem now. Got the headers all bolted up last night ,and fitted to my existing exhaust today. Virgil, the colectors rub on my Front drive shaft like it did on yours. I pulled the collector over with some large hose-clamps around the frame and it clears the shaft now. But by doing that, the flange is pulling away from the side of the head, creating a leak.
I am thinking about putting 2-3 gaskets on, to see if that will fill the gap.
I am open to any suggestions.
i actually cut the header were the slip on part goes
Well i double stacked the manifold gaskets, and that seems to have fixed my problems for now.
Ducky I will probly stick to the 50 series flow for now, but I have plans for 2 single in single out magnaflows with an H or X pipe in front of them. I may even do a Corsa with a side exit in front of the tires.
