Results 1 to 10 of 10
Thread: The trans is f'd....royally
    Apr 2005
    belton, tx
    "The TC has "fused" itself to the output shaft. The pump vanes are blown apart and sitting in several pieces."
    I don't know what that means but it sounds expensive.
    Therefore, I'm gettin' a new trans this week. Tech at GM says he can get me parts cheap "on the DL" and rebuild it with beefier parts that could support 600+ hp. Charging $800-900. With my recent luck, the rear end will shatter as soon as I hit the gas.
    Will keep you updated.
    2013 2wd Z71 6.2 crew cab
    Jun 2004
    george west texas
    damn dude what luck you have...it could be raining pussys outside and you look up and a 12" dick would hit you right between tha eyes well maybe not that bad but....
    you dont even get a chance to take it around tha block whenever you get it fix do you....
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    <div class='quotetop'>QUOTE(stssilverado &#064; Feb 16 2006, 09&#58;42 AM) [snapback]44598[/snapback]</div>
    I don&#39;t know what that means but it sounds expensive.
    Therefore, I&#39;m gettin&#39; a new trans this week. Tech at GM says he can get me parts cheap "on the DL" and rebuild it with beefier parts that could support 600+ hp. Charging &#036;800-900. With my recent luck, the rear end will shatter as soon as I hit the gas.
    Sounds like someone didn&#39;t get the convertor installed correctly before bolting the engine in place and broke the pump.
    Was this with the TCI or Yank Convertor?
    Aug 2005
    Spring, Texas
    Ouch i feel your pain, brotha
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    San Marcos Texas
    <div class='quotetop'>QUOTE(bud8fan &#064; Feb 16 2006, 10&#58;17 AM) [snapback]44602[/snapback]</div>
    Apr 2005
    belton, tx
    TCI is junked. Yank 3200 is going in&#33;
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(bud8fan &#064; Feb 16 2006, 11&#58;17 AM) [snapback]44602[/snapback]</div>
    <div class='quotetop'>QUOTE(GMCwantsLS1 &#064; Feb 16 2006, 02&#58;54 PM) [snapback]44610[/snapback]</div>
    sorry bout your luck , if it makes you feel better my trans is taking a shit on me, i hope it can make it to zippy&#39;s before it blows&#33;
    Feb 2005
    Austin, Texas
    Yes TCI is junk time and again I see them blown. Get a Fuddle converter they are strong as hell and have the best customer service of ANY converter company.
    Oct 2005
    Houston, Tx
    man u need a vacation. for real though sorry to hear that. at least you will on the up and up when you finally make it to the track
    DBYRD Guest
    it doesn&#39;t get better than this u guys really^
