Is it to use two sets of smaller tamer injectors instead of the larger ones that are so hard to get to idle right and have driveability problems??
99' Silverado RCSB Z71: 5.7L Iron LS1, 11.2:1, Custom EPS Cam, Ported 862's,Ported TB, E-Bay Cold Air, E-Bay Long Tubes, Dynomax X-Pipe Exhaust, Electric Fans, Innovative LC-1, Self Built 4L60E, Circle D Pro Single Disc, 4:10 ValueTrac
Or the ability to run straight meth.
2014 Xsport- 3.5 Eco boost
412 Motorsports
I guess a person could regulate the 2nd set of injectors using a hobbs switch at a given amount of boost. When under vacuum at normal driving it can run off one set of rails and when the hobbs switch triggers under boost the other rails fire.
