I just finished a brake job on my truck in my sig. New drilled/slotted rotors, ceramic pads, calipers, and SS lines. It has been at least 10 years since I did my last brake job (not on this vehicle), but I decided to give it a shot.
I bled the system 3 times in a row before I called it good. I was getting a good squirt out of the rear bleeders, but the fronts kinda trickled out. Still, I was pretty sure I got the air out. Bleed sequence was RR-RL-FR-FL. I went through about 1 3/4 huge 32oz bottles of fluid, tried to make sure all the old fluid was flushed out as well.
Took the truck for a test drive and it was immediately apparent all is not right. Pedal moves about 2/3 - 3/4 to the floor before I get any grab. I decided to continue with my test drive and break in the pads and rotors, as it was night and few people were out. Did 6 or 7 40-0 stops, and while it stopped, the braking power wasn't there. Just before I ended my test drive I got a little smoke off the rears.
Still not bled right? I bought a Phoenix Systems bleeder, but I used the old method that day because my nephew was with me and I had him pump the pedal. The only other thing I can think of is if the Master Cylinder went bad and the fronts aren't grabbing. ABS seems to be kicking in when the pedal is on the floor, but very weak.
Major brake system failure is what prompted this brake job before I was ready to do it. I knew the brakes were going bad, but still had to keep driving to save money for the repair. Finally, coming down a hill to a T-intersection, the pedal went to the floor and it was all I could do to get the beast stopped before I hit someone or ran through the intersection into the opposite bean field.
Left rear rotor was completely destroyed when I took it apart. The outside surfaces of all 4 rotors looked good. The inside surface of the other 3 was only getting about 3/8in contact in the center. By FAR the worst I've ever seen heh. Yes, I took pics and I'll post when the truck is back on the road.
Suggestions? Try the bleeder tool I have first, and if that doesn't work, replace the Master Cylinder? Something more involved? I didn't have the typical "soft pedal" complaints about my brakes before, as is apparently typical of trucks of my year range. However, I also accelerate and brake like a grandma.
Input appreciated! I want my truck back![]()
I'm sooo happy to finally have my truck back!
