Results 1 to 10 of 15
Thread: Aluminum Intake Pipe
    May 2006
    San Marcos
    I'm thinkin about making an intake out of aluminun pipe and adding a K&N to avoid spending $300 on the kit. Do you think that the aluminum pipe will produce higher intake temps than plastic? Is this a good idea?? ANyone done this before? Any suggestions would be great.
    2006 Crew Cab Vortec Max 6.0L - Tune by Allen.
    14.57@94mph
    my aluminum tube gets damn hot. I'd do plastic if you can.
    May 2006
    San Marcos
    <div class='quotetop'>QUOTE(RedHeartbeat &#064; Jun 23 2006, 03&#58;10 PM) [snapback]56114[/snapback]</div>
    my aluminum tube gets damn hot. I&#39;d do plastic if you can.
    cool, thanks for the input man
    14.57@94mph
    May 2006
    Bakersfield,CA
    hey what type of gas milage do you get with your 6.0
    2006 1500HD Intake and HPtune,Cognito Steering kit, comp 218/224 cam
    1994 chevy P/U 1500 Sportside 330 H.O. Crate 4.11 Eaton posi. 150 Wet Nitrous Holly kit w/t external full cell
    E.T. 14.2@102mph on (20&#39;s)
    http://i15.photobucket.com/albums/a3...ure200X600.gif
    1994 chevy
    http://vids.myspace.com/index.cfm?fuseacti...eoid=1435245725
    2006 1500HD
    http://vids.myspace.com/index.cfm?fuseacti...eoid=1135635224
    May 2006
    San Marcos
    <div class='quotetop'>QUOTE(Lethalyoyo &#064; Jun 24 2006, 09&#58;39 PM) [snapback]56189[/snapback]</div>
    I have a crew cab 1500 and I get anywhere from 17-20 on the hwy and about 15 in the city...depending on how my foot is in it
    i only have about 3000 miles on it, so hopefully it will get a little better...
    14.57@94mph
    May 2006
    Bakersfield,CA
    <div class='quotetop'>QUOTE(MXHonda97 &#064; Jun 24 2006, 10&#58;20 PM) [snapback]56192[/snapback]</div>
    i need to find out what the differance is between our motors i am only getting 12
    1994 chevy
    2006 1500HD
    Jan 2006
    HEY,
    I HAVE A 6.0L AND IT GETS 20-22 ON THE HIGHWAY DUE TO THE STS TURBO AND THE NELSON TUNE. I AM RUNNING A 373 LOCK UP REAR.
    I HAD AN ALUM. TYPE INTAKE AND IT RAN FINE I THINK IT WAS A BRUTE FORCE INTAKE. IT LOOKS SIMPLE TO MAKE AFTER I BOUGHT IT. THE ONLY THING YOU MAY NEED IS THE 90* FITTING INTO THE THROTTLE BODY.
    JAMEST
    12 Sec. Club! SOLD
    SOLD***
    Sep 2004
    Breaux Bridge, LA
    <div class='quotetop'>QUOTE(MXHonda97 &#064; Jun 23 2006, 01&#58;49 PM) [snapback]56108[/snapback]</div>
    I&#39;m thinkin about making an intake out of aluminun pipe and adding a K&N to avoid spending &#036;300 on the kit. Do you think that the aluminum pipe will produce higher intake temps than plastic? Is this a good idea?? ANyone done this before? Any suggestions would be great.
    it would be best to use pvc with some sort of cone filter and custom made box.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    May 2006
    San Marcos
    <div class='quotetop'>QUOTE(bluecajun5.3 &#064; Jun 27 2006, 09&#58;36 AM) [snapback]56402[/snapback]</div>
    Is that what you did, if so do you have any pics???
    <div class='quotetop'>QUOTE(Lethalyoyo &#064; Jun 27 2006, 01&#58;06 AM) [snapback]56396[/snapback]</div>
    Looks like you have a 1500HD 4x4?? Mine is not the HD and it is 2wd.
    14.57@94mph
    Sep 2004
    Breaux Bridge, LA
    <div class='quotetop'>QUOTE(MXHonda97 &#064; Jun 27 2006, 11&#58;50 AM) [snapback]56411[/snapback]</div>
    yes, here you go...
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
